Fuse snapped off - what to do?
scottp999
Power outlet 15a fuse blew this afternoon when using a 12v compressor. Went to replace it. It felt like it came out normal but both ends are left in the slots. What's the normal solution. Go get a new fuse panel from the dealer and move everything over to the new panel?
Thanks!
Not trying to be a dick,
But is it possible that this is the first time you've replaced a
Micro blade fuse? There's not really anything that sticks out that could break off...
Can you post a pic?
Can you post a pic?
+1
A picture paints a thousand words.
May be OK as stated above. If not, use small needle nose pliers or a small pick tool and remove the remaining parts. Try to not let the tool touch any other metal parts while doing this or disconnect the battery for safety.
Can you post a pic?
I really appreciate the quick reply. Yes, I think you are right. New type of fuse to me (interior fuse panel). This is on a 2010 4runner limited. Looking at https://en.wikipedia.org/wiki/Fuse_(automotive) it looks like the low profile mini fuse (not the micro) which would mean, yes, it's the first time I've ever seen one, and I assumed incorrectly that it was a standard length mini fuse that snapped off. I am relieved and learned something new. Thanks again!
I'm pretty sure I had the same reaction when I pulled a fuse to install my dashcam.... it was the first time I'd seen a low profile mini fuse as well!
Glad to hear nothing is messed up.
Regards,
-rob
At my shop I refer to this style of fuse as the "Lieutenant Dan" fuse (because it has no legs) and my parts guys know exactly what I'm talking about! LOL
