Gas leak around fuel pump on top of gas tank
TeamUSA
2000 Toyota 4Runner SR5 3.4 V6
I discovered a small amount of gas leaking from the top of my gas tank around the fuel pump. The previous owner replaced the fuel tank 5 years ago with a tank from a 1998 4Runner. The car turns over fine so Im assuming the pump itself is working fine. Somehow the seal around the pump is not. Is there a replacement gasket I can buy to seal the pump into the tank? Or could I get some silicon sealer or something and just spread that around the edge of the pump?
First determine that it really is the rubber gasket between the plate and the tank that has lost integrity. No rotten/rusted fuel lines/hoses in the area?
As I recall, the gasket is available as a separate part; check one of the online Toyota parts dealers that has the parts drawings to see it/price it.
Camelback Toyota says it's $9.49.
I wasn't sure if there was a gasket or not. All my fuel lines look to be in good shape to me.
There is an access panel under the carpet drivers side rear seat. It is used to unplug the fuel pump/sending unit, but is a great window to see what is really leaking.
My leaks were the fuel return and sending lines. Swapped the fuel sending unit bracket and new rubber gasket out. I did have to drop the tank.
9 times out of 10 it's the metal lines coming out of the pump that are rusted and leaking. Very common problem, just went through that on my Trooper.
Runvod
