Gas pedal grind/vibration 1k - 1500
FamousAv8er
I’ve been noticing a grinding feeling through my gas pedal at about 1000-1500 rpm. Feels like something rotating around and scraping. Usually occurs while turning.
I recently did a power steering fluid change but not sure if it came about before or after the change.
Anything I should check or is this normal?
I forgot to mention Im in a 4wd SR5. The rubbing I feel is in 2wd and havent attempted 4wd
also this is occurs only when turning
original brakes? it could be something as simple as worn brakes, worn out pads can make a scraping sound when turning even when the brake isn't applied.
Seems I’m having trouble duplicating the issue today. It’s about 80F here so could be similar to the needle bearing issue.
If it was the needle bearing would I be hearing a sound? Could I hear it parked?
If my bearing is out, what issues can I expect if I’m not able to diagnose or address it right away?
yes original brakes, I will check those out as well but just 6k ago the dealership said they had plenty of life left
Have you discovered the issue? I've had this same issue for quite some time now. Vibration through the gas pedal only and only while turning at low speeds such as making a turn from a stopped position. I can't hear it, I can only feel it through the gas pedal.
Ive had rare occurrences of the same situation in my 5th gen, I'm pretty sure its the rotors or brakes on mine, so it probably may be your braking system.
