gas tank rub on frame with susp flex
swerks
Member
Any one have a problem with gas tank rubbing on frame with suspension flex ?? mine seems to make a clunk at times. I was able to shim it with some rubber pieces but I don't think this is a permanent fix, any suggestions ???
Your tank shouldn't be hitting your frame.
I'd check bushings etc. Make sure your tank mounts are in good shape. I never had that sort of problem even dragging my 81 Trekker across rocks
DJNutshell
