Gasket Material critical? - master cylinder to brake booster
greeney
Is Gasket Material critical for master cylinder to brake booster? I notice the old one is paper thin and the one I cut from a roll I got at Autozone is thicker and a soft material. Not sure if this gasket is there more to stop vacuum leak or brake fluid leak.
I don't think the gasket seals vacuum, and it definitely does not seal brake fluid. I think it is just to keep moisture out.
31ectr0nicb0b
