Gauge lights out. Bulbs or fuse?
if in case your problem is with both your gauges and running tail lights not working, as well as your front markers, it's a fuse
there is a 10 amp fuse that always blew for me. Its in the fuse box under the hood and it's called TAIL 10AMP
It kills the corners, tail lights (not brakes. running lights when the lights are switched to ON), and the interior lights.
I blew through something like 5 fuses so I swapped it with a 15Amp about a year ago, no problems since.
course its the upsidedown one :D
it also takes out all the dash lights which he said still worked
Littleton/Centennial area,
Well, when you get the new LEDs be sure to let us know if that fixes it... I cant believe the dealership wouldnt have checked out the lights to make sure they worked before they sold it to you?
Yeah, I was pretty pissed off last night... Do you know which plug provides power to the panel? I would prefer to just plug one in to check polarity as opposed to all four.
ETA-Ahhh crap...I ordered 74's instead of 194's. ****.
I just changed the three 24's that illuminate the gauge cluster because the bulb near the temp. gauge was out. I replaced all three. I put the dash back together and all three worked perfectly. Tonight I took a short ride to the store and when I turned the lights on, the temp light was out again. Is it possible that the socket that the bulb fits into is bad? The other two are still working fine. Help!!
workingwheelswnc
