Seeking help with a similar R flashing issue
IBallEngineer & TheDurk - I know this is an old/dead post but I don't believe I've been on/posted enough to start my own posts yet.
This is the first post I've seen with a somewhat similar issue - the R flashing with the turn signals (ECT also flashes with turn, Hazard causes a similar flash & turning on the interior dash lights - click 1 or 2 on the steering column causes the turn signals to flash the wrong direction)
I've had my '02 SR5 going on 2 years & love it but my OCD is going crazy with the gremlin I let in the electrical - do one of you think you may be able to assist trouble shooting with a bit more detail.
This all occured after an LED light swap at the same time I sound deadened - I knocked out the amp with the sound deadening - degreaser killed the chassis ground - found that - just can't figure out the electric.
Seems like IBallEngineer has the scoop on how everything wires together!
thanks in advance...
HEY, I engineer things all the time, like lunch.
First glance at this situation, and [MENTION=10169]TheDurk[/MENTION] is right I do love these things, both the R indicator light circuit and the RH turn signal circuit go through connector 1H at the Driver's side J/B. Pin 5(R Indicator) and Pin 13(Rt Turn) are right next to each other. Coincidence?
opcorn:
