smccollamjr
How do I tell what the gear ration is on my '02 3.4L without removing the diff cover and counting teeth?
smccollamjr said:How do I tell what the gear ration is on my '02 3.4L without removing the diff cover and counting teeth?
A good rule of thumb:smccollamjr said:How do I tell what the gear ration is on my '02 3.4L without removing the diff cover and counting teeth?
peter78 said:A good rule of thumb:
3.73 @ 2000 RPM 67 MPH (2WD models)
4.1 @ 2000 RPM 60.5 MPH
4.3 @ 2000 RPM 56 MPH
Them's fighting words boy.:headslap:ebelen1 said:Almost. The 2WD has 3.90's.
peter78 said:Them's fighting words boy.:headslap:
3.4-liter 2WD and 4WD with 4ECT
Ratios 1st.........2.804
2nd.........1.531
3rd.........1.000
4th.........0.705
Reverse.....2.393
Differential Ratio.... (2WD 3.727)
There's an axle code on your lf door jam... it should have 4:10s
You are both correct. If the 4Runner had 225/75-15 tires when sold new it was 3.73 and if it had 265/70-16 tires when sold new it had 3.90s (both 2WD auto). V6 4WD Auto will generally have 16's and 4.10's, but certain options or smaller wheels can change that.Them's fighting words boy.:headslap:
2nd.........1.531
3rd.........1.000
4th.........0.705
Reverse.....2.393
