Gear Ratio
smccollamjr said:
How do I tell what the gear ration is on my '02 3.4L without removing the diff cover and counting teeth?
There's an axle code on your lf door jam... it should have 4:10s
Could be 4:30's if its got a locker, thats what i have in my junk. Locker might not have been an option after 01 though, i forget what year that stopped.
A good rule of thumb:
3.73 @ 2000 RPM 67 MPH (2WD models)
4.1 @ 2000 RPM 60.5 MPH
4.3 @ 2000 RPM 56 MPH
Re: Re: Re: Gear Ratio
ebelen1 said:
Almost. The 2WD has 3.90's.
Them's fighting words boy.:headslap:
3.4-liter 2WD and 4WD with 4ECT
Ratios 1st.........2.804
2nd.........1.531
3rd.........1.000
4th.........0.705
Reverse.....2.393
Differential Ratio.... (2WD 3.727)
Re: Re: Re: Re: Gear Ratio
2nd.........1.531
3rd.........1.000
4th.........0.705
Reverse.....2.393
To be honest, I don't even understand all the different ratios you posted but I was told that I have 3.90's. If I have less, that would explain the power loss. Will be upgrading to 4.56 before Christmas.
2nd.........1.531
3rd.........1.000
4th.........0.705
Reverse.....2.393
You are both correct. If the 4Runner had 225/75-15 tires when sold new it was 3.73 and if it had 265/70-16 tires when sold new it had 3.90s (both 2WD auto). V6 4WD Auto will generally have 16's and 4.10's, but certain options or smaller wheels can change that.
Most door stickers call out 15" wheels even though many/most had 16's - so you have to look at the axle code for a first reference... then do a spin test since swapping a 3rd member is easy and could have been done any time in the last 25 years... (mine came with 3.73s, then swapped to 4.10s and now has 4.88s, for example)
-Charlie
Almost there. 2WD V6 with 225s had 3.73. 4WD V6 with 225s had 3.90. 2WD V6 and 4WD V6 with 265s had 4.10. I have a rear axle from a 2002 Sport Edition 2WD in my 1998 4WD Limited.
