Gear ratios for the 5th gen 5spd
wfo9
I've looked everywhere I can think of. The Toyota site is absolutely useless and provides no detailed specs on the transmission or anything else for that matter.
I know the stock final drive is 3.73 and that 4th is probably 1:1.
Anyone know what
the 5th gear ratio is? 1-3 would also be nice to know. Trying to calculate out what a gear change to 4:56 would yield on my setup.
The manual may have it, but I don't have that with me at the moment.
Anyone know what
Toyota's 2011 4Runner Product Information sheet lists gear ratios. You can find it here:
2011 Toyota 4Runner Product Information | Toyota
Gear Ratios
1st 3.52
2nd 2.042
3rd 1.4
4th 1.0
5th 0.716
Reverse 3.224
Differential Ratio 3.727
Transfer Case (High/Low) 1.0/2.566 (4x4 SR5, Trail only)
Grimm Jeepster
Perfect! That is the elusive spec sheet I have been looking for.
Gear Ratio Calculator
Use the Toyota A750F for the transmission and the tacoma and FJ choice for the dif and this will give you every bit of info you could possibly want.
End Ratios for highway and Crawl in every gear
speed in each gear for a given RPM or vice versa. Takes into account tire size.
I updated the entries. It calls out the 4Runner on that transmission now. :)
Though it does seem quite wide because of all the information I added. I'm going to see about narrowing it back down...
I almost didn't answer this cause I figured you'd see it but I wasn't sure how often you checked in.
I don't check in every day and I miss things once in a while. My 4Runner order has been postponed due to a potential for me to be moving for a new job so I don't have a lot to chat about yet.
Philthyphilthy
