So, if you had the option of putting in a 4.10 locking rear diff or putting in a 4.30 and changing the front diff as well (Manual tranny), which would you choose? The 4runner is lifted 3" as well with larger tires (I believe they are 31" or 32" tires)?
Would the 4.30 gearing make the speedo that is setup for 4.10 more accurate (if the 4runner is lifted with larger tires)?
Will the 4.30 gears will hurt the mileage some right (not that the lift doesn't)?
