Gen2 Transmission issue/New owner
VenomGEN2
I've looked around threw threads and couldn't find any answers but I'm new too owning a 95 4runner SR5 w/4WD. It's been shifting fine the first few weeks but after a while I notice it's shifting oddly(erratic shift points) and not shifting into o/d. I've been trying to figure out what solenoids too look up for the transmission and or if there's a sensor that maybe malfunctioning.
There maybe a sensor or shift solenoid that could be the problem. Have you tried servicing the tranny
Trans Fix
Remove all solenoids from the transmission. Test each one with current to find the bad solenoid (positive/negative) - the one that will not open and close when current is applied is the bad one. If you don't know how to test them, take them to a transmission shop. A good transmission guy will help at no charge, only takes a couple of minutes. Replacement cost for a solenoid is pretty cheap. Buy off of eBay for the best deal.
Thank you for your I will deffinitly give that a try because I didn't know you could test them but thank you.
Have you checked to see if any trans trouble codes have been generated?
A bad solenoid should generate a code.
Would the check engine light stay on for a trans code or something? Cause there isn't any light on the dash that indicates a problem
delislerebecca
