General Grabber vs Nitto Ridge Grapplers
You can go to Discount Tire Direct, enter your vehicle, then choose the tire size, and then search by Treadwell. That will give you lots of independent tire testing. The ATX gets good reviews here and not so good scores on the testing. I have no idea, personally. Never ran any Generals.
Also, remember that tires play together with shocks and springs. In my experience, lighter duty shocks springs go well with SL tires and heavier duty suspension with heavy tires. My current LTE tires on a stiffer suspension actually feel better than SL on the same. I am not sure about the engineering specifics but tire weight is one part of the story.
Ha! I just put my first 300 miles on the sibling ATZ P3 and cannot have been more impressed. Offroad is obvious, but I have been shocked by how good they have been on road with my heavy duty suspension.
I was about to pull the trigger on 285 Nitto RidgeGrapplers for this reason, aside from the Cooper's AT3 4S they are the only other 285 size SL tire in a non-LT that runs around 45lbs each or about 20lbs less than every other General/etc option. So overall wear and tear on suspension, engine drive components and lost MPGs on top of obvious performance differences still leads me to the 116 rated SL Ridge's. Better rubber compounds, from a brand that has been doing performance tires much longer than most others.
Ambrose67
