Getting ducks in a row
JamesDean91
Alright this may be a little hard to understand but figured I would attempt and ask.
I have a t4r with the factory elocker, I'm building a set of 9" axles with arb lockers. Has anyone seen or think it is possible to wire the elocker system into the air locker system? I'm sorta fond of the abs shut off and would like to keep that function.
I have not decided if I just want to pull the whole elocker and abs system out and wire everything new.
simplest thing would be to simply do the ABS switch mod , wire a switch into teh main abs fuse and simply cut the power to fuse when you want to kill the abs, easy peasy and plus you get and extra cool switch on the dash next to the locker one! or tie the locker switch to the abs directly with the wiring but that would be a mess and introduce failure points, and as far as mating the two systems that would be a nightmare imo....the best ,easiest ,cheapest thing to do is simply cut power to abs fuse with a switch in the dash...
That's exactly what I was thinking.
Not even sure if I am going to be able so keep the abs system but if I do I will probably do exactly that.
Ambrose67
