Getting the most out of my 22RE
gotmud?13
Banned
Hey all. i have been doing some research, and have found several things to do to my 87 22RE, such as headers, stroke it out, bigger camshaft (when they mention this, they say DOA cam. what does DOA mean?) cut out the cat, 2.25 exhaust, and k&n filter. my question is, where can i obtain these items to pimp my runner out so i can actually pass people on the highway? also, would a 22RET swap be a good choice?
A turbo would give more power than any other mods! Beware of burned/eroded turbine housings around wastegate valve. OEM 22re turbos are notorious for this.
DOA means DOA Racing. They make cams and higher horsepower 22RE engines. Like the one in the photo that's in my 4Runner.
Check out LCEngineering, Engnbldr.com, and DOA Racing. They all have websites and lots of performance mods for 22RE engines.
Still not sure if you'll be able to pass people! :D
yah i have the same problems
it kinda sucks when i cant get to
75 so easy i was thinking headers and
a short ram but am sure it wont get
enough ponies, how much would putting
a turbo on it cost all together
thanks for the replys. Alabama4Runner you have been a big help. i think im just going to live with my engine the way it is now, maybe a new cam, and then in spring, go to a bone yard, and pull out a 22RET. how common are they? 4runninAZ, turning a n/a (naturally apirated) vehicle in to a forced induction (either turbo or supercharger) is a hard and painstaking process. i used to own a 94 probe gt, and i was quoted $6000 to have a full turbo setup, mind you thats with intercooler and aftercooler, oversized wastegate, and compact hotpiping kit, yada yada yada. of course a basic turbo assembly wont cost that much. think about this for a second. if normally, you run around .77 psi boost, and you suddenly ram 16 more psi boost into your engine, it WILL detonate, and blow your engine to smithereens. so you have to have a timing re****er, that is in sync with your boost pressure. i have heard of some engines that have -53 degrees timing, under 20 someodd boost psi. you also have to rig up some kind of extra fuel pump, as under almost full boost, your intake runs lean, so you need more fuel at higer boost and rpm. you also need a wastegate, which regulates the amount of exhaust going to the turbine side of the turbo, therefore regulating the amount of boost psi your engine can handle. you also have to have a blowoff valve, as think about this. if you stomp on the gas after a corner, and are running 17 psi boost, and then some deer or some drunk on a lawnmower drives out in front of you (lol) and uyou have to hit the brakes, while you are running 17 psi boost, you will have -17 psi of boost between your turbo and carb (if you are blowing through carb) or between your carb and turbo/intake (if you are sucking through the carb), and it will absolutly kill the engine, to idle speeds for a good section of time, and in some cases even stall your engine. the blowoff vavle is that hissing steam noise you hear from any ricer civic if they have a turbo and they let off the gas. there is so much more involved in installing a turbo, to anyone who would like some more information, and some mathematical calculations, or just some questions, please feel free to PM me. so 4runninAZ i hope i answered your question enough. that is the reason why i am doing the 22RET swap, as it already has all the necessary mods done to it, and i can just install a biggetr turbo, (possibly a Garrett a/r 89 or bigger turbo, or possibly a schwitzer) because i dont have time/money/patience to add a turbo to my stock 22RE. so what i am going to do, is buy a 22RET, tear it apart, bore/stroke, port/polish, new heads, cam, headers, bigger turbo, as max compression as i can go (probably like 8.8:1 or 9.5:1) and clean it all up, and hopefully run around 250-300 hp on medium boost. again, thanks for the help, and i hope that i can help any of you that have questions regarding turbo chargers. thanks,
Jake Engel
Good luck. I would say if you can get more than 200 hp out of a turbo 22RE then I will fly to Canada and buy you a very nice dinner. :D
Great goal but DOA Racing only show 170hp max for their built tubocharged engine. There just isn't enough displacement.
Anyway, let us know how it goes.
i was thinking about the chevy small block swap, but it requires a LOT of work. immense amounts. downey has a good chev/buick swap guide that i downloaded a while ago, but a simple google search would solve that.
what type of engine is the 5VZ? i havnt heard of it. i was thinking about the supra 7MGE or the 7MGET (turbo) but that also requires some work. anyone know where i can get a 2JZ? lol just kiddin those are RARE, and it probably wouldnt fit. is there any swap sites on the 5VZ?
The 5VZ is the 3.4 liter V6 and is a really good engine. I have had 2 Tacoma 4x4 trucks with that engine and they had plenty of power.
