Glove box and footwell lights not working
Schrek
Hi, I'm hoping someone on here understands how the glovebox and footwell lights are wired. I have a 2012 Limited and noticed tonight that both my glove box led and the passenger footwell led are not working. I don't know how those leds are wired into the harness but I'm assuming there is a single point of failure upstream from both lights as they aren't working. The footwell led on the drivers side is working just fine.
Any suggestions?
Thank you!
Did you have any work done in that area like the air bag recall replacement? You could also check both locations for loose bulb / socket or anything broken. I'd check fuses first as previously suggested; and then voltage at the socket/s.
The airbag was impacted by the recall - I'll check the voltage and then check all the connections.
alexaturner
