GMC/Toyota rim match
longdrive
I have been told from a friend that 18" P265/65/R18 GMC 6 bolt rims will fit my 06 4runner no problem. I currently have the same stock/factory tire and bolt pattern but I don't know if the spacing or rim depth would be the same, I don't think he is an expert so I will defer to the experts on this site that might know the real answer.
Thanking you in advance for any feedback.
I believe they'll work fine as the lug pattern and the bore size is the same IIRC. As for backspace/offset I don't know. What are the specs (width/BS) on the GM rims?
The reason I replied is to point out a potential lugnut challenge. You may need to get a set of conical lugnuts to use with the GM rims. IIRC GM doesn't use the same style lugnuts as Toyota.
There is a set of new tires that I looked at that are on GM rims so I thought I would run those for the winter and save my nice rims from eating salt and sand all winter long, they are a good winter tire and I would basically be getting the rims which are new for free......... at least that what I was thinking.
