Good shops in SoCal area to do X-REAS lift install?
sequoia10
Anyone have good (or bad) experiences with any shops that are willing (and most importantly able) to install lift kit on 4th gen 4Runner with X-REAS suspension?
I'm looking into installing cornfed lift until get around to replace entire suspension, when the OE shocks start to wear out....
Its gonna be tough to find a shop willing to do it. shops that know about the xreas will stay away and shops that will do it, probably dont know what the xreas is and might damage the xreas.
my advice: get some hand tools, rent a spring compressor, invite a buddy over and do it at home. thats what i did and it turned out great.
good luck.
The rear is simple, the front is a little more involved. Read the link in my sig (click where it lists my lift/tires) and that should give you all the info you need to tackle the install yourself. I was hesistant at first, but with the help of a fellow member we were able to do it pretty easily, just take it slow and you'll be fine.
Where in SoCal are you?
I have done the spacer lift with XReas and will be installing FJ Springs this Sa****ay. If you want to come by, I can show you what needs to be done and what to look out for. It's really not hard, just a little time consuming.
