Got some Jeep aftermarket fog lights. Is there any way I can make it work?
PeoplecallmeIan
As the title says, I was given some test LED fogs from my company but the connectors are for a jeep. Would I be able to switch the Jeep connector to match the H16 connectors.
The lights are pretty cool. They are Halo LED's with LED fog lamps. They do fit the housing perfectly because I test fit them to the holes. Just wondering if they would work. I don't want to mess any electrical stuff up.
They are kinda like these:
https://www.amazon.com/4XBEAM-Impre...ocphy=9031000&hvtargid=pla-450948768643&psc=1
Positive to Positive, Negative to Negative. You'll need to tap the DRL circuit or a corner light for the halo. Mounting will be probably be more challenging than wiring I would think, but if it has mounts like the one you linked to I think you could make it work. My Morimoto fogs have mounts very similar to those, and I only used 2 of them per side
