got some new black headlights. help me make sure of proper install
ddnww
Mainly, what are these little blue plastic things for. I'm assuming something to do with wiring.
It didn't came with any instructions? The bunch of wires coming out of the housing is for your LED halos and the little black box is called 'driver'. You need to connect those wires with the help of blue crimps to your factory wiring by the means of splicing. Where you going to connect, is depends on what you trying to achieve with your halos.
I Will tap into the running lamps
On the daytime running lamps there are two wires. Green and white with black stripe
Which is positive and which is negative
Unfortunately I have nothing to contribute that would facilitate your install, but I'd love to see some pics when your done and your thoughts on them b/c I really like the look of those!
Thanks and best of luck.
Same here. They look great in the pics. I'm interested to see how they look installed and the light output. Thanks
Installed
Just the halos, without the hid's
They look like they fit pretty well to the body also. Did the bolt holes all line up ok?
yes they fit and bolt up perfectly, only problem I had was on the drivers side headlight one of the lights didn't exactly match up where you push it in and turn to lock it in place. So I had to do a little trimming for it to fit in.
thadjay
