grease fittings on 04
Larry said:
Where are the drive shaft grease fittings on my 04 2x4 V8 4Runner?
If installed, there should be one in the center cross of each U-joint, and one on the side of the slip joint.
If I can't find them, then there is no greasing required?
I had just read that you needed to grease them every 5k miles.
If they are not there, I guess you don't have to grease them.
My 03 Sport has Zerks. Maybe you need to rotate the drive shaft (backup two feet) and inspect the other side? It would not surprise me if you have none however because the 04’s changed to longer lasting coolant & Tranny fluid. I guess the 04 models have a lower maintenance campaign going on.
I felt around everywhere my fingers could reach and found nothing. The book says otherwise. Anyone know for sure what's up?
I was under the truck about a week ago inspecting things, and I'm almost positive that I saw one zerk in the cross on the rear driveshaft at the transfer case end. I didn't look for the others.
I'll check it again this weekend, since I'm planning on doing the first oil change.
Does anyone have any brand/type of grease they recommend? I've used the Mobil Synth, and plain old hi-temp grease on previous vehicles. I know certain grease types shouldn't be mixed, but I wasn't sure what Toyota uses.
--Mike
I have an 04 V6 4wd 4Runner. I have a number of grease fittings on the front and rear of the driveshaft. I don't remember exactly how many but if you look again, they're there.
i've got mulitple fittings on mine. i use valvoline synthetic and grease with every oil change or two. (3-6000 miles).
Larry said:
Mine is a 03 V8 2x4 and I'm talking about the driveshaft to the rear axle.
At either end of the drive shaft, there is a universal joint. The front one connects the drive shaft to the yoke that fits into the back of the trans. The rear one connects the drive shaft to the flange that attaches to the rear diff. The U-joint is a cross shaped device with bearing caps at the each end of the cross which fit into sockets of the shaft or yoke. In the center of each cross piece, offset at an angle is a zerk fitting (looks like a small nipple). This is the grease fitting. It is usually easier to jack the rear end of the vehicle off the ground, so the rear wheels can spin. Then you can turn the drive shaft until the fittings can be seen. A grease gun fitting on the hose snaps onto the zerk fitting, and grease is applied to the joint. There is also a splined slip joint in the drive shaft, somewhere between the two u-joints. On the side of this slip joint is another zerk fitting. This is the fitting which is used to lube the slip joint, which is the cause of most 'thump' feelings after hard braking.
I'm trying to figure out how to upload a picture.
If it works, it's a picture of my driveshaft with no zerks were everyone says there should be zerks.
Well, here's another try. A driveshaft with no zerks as described by others....
