GREENAMPHIBIOUS' Build and Adventure Thread
AWESOME..... now that is all taken care of....
Placed an order today
ICON Stage 2 lift with tubular control arms
BFG KO2s 285/70r17 (Going on factory wheels)
Not sure if I will need spidertax or not
Side note: rigid D2s get delivered today!
You got 50231H, right?
There is a batch of 50231H boxed up with an incorrect instruction.
If yours looks grossly different than this, you may want to try this instead.
> Hi/Low wiring instructions:
> P1-A(Red wire) On the harness connects to 2A on the switch
> P1-B(Red & white wire) on the harness connect to 3A on the switch
> P1-C( Red wire with black heat shrink) on the harness connects to 1A on the switch
> P1-D(Black & red wire) on the harness connects to 1B on the switch
> P1-E( black wire) on the harness connects to 3B on the switch
> Your last 2 wires can also come out black, for P1-D & P1-E
Oh or did you just ordered a pair of D2s? If so, just ignore what I said above.
Hmmm..... wait..... you ordered 20211, right? Those are a pair of Duallys, not even D2s..... right?
D'Angelo
