H
bonds44
just wondering if any one has who has HID's low beams has color matched their fog lights as well and was wonder how they look? if u have done this pls. post pic's if possible and if the matching fogs make any difference from stock? and if you haven't done this what do think of matching fogs and low beams or should i just go with the yellow Endurance fogs
heres the link
http://www.hoen-usa.com/index.htm
I thought about putting HID's into my fogs, but I decided that it would just be to much glare. The Hoen's look like a good deal - they're cheaper, will give the look, and won't produce glare at the same time.
I have the Hoen's in my fogs and low beams I don't have HID but on a side note I love these bulbs.....I've had Piaa's,Hella,Silverstars, etc..... in the past and these by far are my favorite, The other bulbs have always burnt out to quick for me.....so these are great....
are you running the 80W bulbs in your headlights?
Nope I went with the... H11 Hoen 55W xenonmatch bulb pair but I'm gonna upgrade to either the plus or the titanium.....i'm leanin towards the plus....
Sportrunner, are the bulbs the same for the low beam and the fog lights? Is so do you need anything else or can you just remove the old and plug in the new?
Thanks Keith
I believe the fogs are 9006 and the low beam is H11 and the High Beam is 9005, just make sure if you get the higher watt bulbs you get the harness upgrade for $10 bucks, just as a precaution... I don't know if you have to splice some wires for the new harness or not but should be easy and then just plug bulbs in like usual...
