H11a or b?
Don't have the vehicle currently at my disposal to check. Are the low beam bulbs H11a or b's?
I didn't know the difference between A and B, so I googled it to compare to my pics. My guess is B, but I don't really know. This is a pic of the back of my 06-09 Headlights
edit: looks like whatever source I used wasn't very accurate or I don't know what I'm looking at. Sounds like its actually A
A simple web search turned up that Toyotas are primarily H11A style. Took me less time to find that out than to post the answer here.
Sent from my SM-G986U using Tapatalk
Your passive aggressiveness means nothing to me. I spent 30 minutes searching with no definitive answer which lead me to making this thread which will now aid others in the future.
There was no passive about it, or me for that matter. It was literally the first thing that popped up for me when entering "H11A vs H11B 4Runner"
Oddly enough, I never have been asked if H11A or H11B. I order H11 they show up from the UK and they fit and work, every time. Same for when I buy them at the store.
Who knew?
:art:
It more obvious than bulb orientation...the main difference with H11A and H11B bulbs...at least with incandescent bulbs...is how it 'plugs' in.
The H11A bulbs have the traditional external plug socket where the connector from the vehicles 'plugs' into the bulb.
The H11B...I know this because I have a '08 Sorento (H11B) and '16 CRV (H11A) in the fleet...does not have a traditional plug socket...it has 2 prongs (+/-) or tabs that slide into a type of socket built or attached to the headlight assembly near the bulb socket.
(KIA and Hyundai like to use the headlight assemblies that have just 1 large plug for the entire assembly rather than individual connectors for each bulb in the assembly. So, I guess that's why they used the H11B...stick it in, turn it (empty your wallet) and your done.) Plus, H11Bs are harder to find...I don't think Toyota would go that route with something as simple as bulbs.
Be glad that you use the H11A bulbs...for some reason, the H11B are 2 to 3x more expensive than the H11A.
OP are you looking for halogen or plug n play HID bulbs?
Halogen - H11. As Swamp mentioned a halogen H11b has a totally different electrical connector than the traditional H11.
HID-wise, if the seller offers an option for A or B, it's usually B. Some PNP HID bulbs are only offered as a single H11 base, like Xenon Depot, but luckily the return wire and tabs are at the correct position for a projector light assembly. A H11a will fit, but the return wire will cause a "shadow" on the beam pattern.
The widest notch on your headlight pic appears to be in the 11ish o'clock position, so it should be B.
Ohhhh there are different As and Bs for Halogen and HID. Interesting, learn something new every day
if your doing the HID kit, its H11B for stock toyota projector headlights.
maybe save up and do a true hid projector retrofit?
itll be much better and worth it.
