Harbor Freight Roof rack
metallitera
that actually looks pretty good and a great price. I have a rola rack and it has too many things i dont like about it so im thinking of switching
I bought one and set it up for my 2nd gen 4R. I can fit a fuel can, water jug and cooler on it. Good quality and value for the price. Easy to remove and install to the factory rack.
i saw the dimensions online, but i could not tell if it was the top or bottom dimensions. Cause the top opening is slightly smaller.
Also do you know if standard hooks for straps fit around the upper tube? My rola upper tube is so big it doesnt allow for it and sucks.
I don’t know if a Curt extension will fit. Area is not an issue for me, the 2ng gen factory rack is rated for 100lbs. The Harbor Freight rack weighs 27lbs and with 5gal of fuel and 5gal of water I am already maxed out by weight.
The upper bars are 1” diameter and the lower cross bars are 1/2” and my strap hooks do not fit the upper bar. I made and attached a plywood base and bolted down my Wavian mount and added tie down rings to strap down the water jug and cooler.
would you be able to take some photos of how it sits?
DexterShaYang
