True, and they are included with the NAPA pads as well. There's just one BIG, HUGE PROBLEM w/the NAPA's Super Premium pads, and I would assume the AutoZone pads as well....
There are only two benefits to going w/the bigger tundra caliper... 1) fluid capacity, 2) Larger brake pad, which results in a larger swept area on the rotor.
Take a look at your pads. You MIGHT notice that on the AZ pads, they have a beveled edge on both sides of the pad material. If so, this beveled edge significantly reduces the amount of contact the pad is making with the rotor. As the pad wears, more and more of the pad comes into contact with the rotor.
This ends up completely negating the 2nd benefit of going with the bigger caliper....at least until the pads have worn down to where the beveled edge is gone, and by then they are almost worn out.
TOYOTA pads are designed in such a way that the entire pad surface is contacting the rotor from Day 1. They end up costing more once you fork out for the shims, but I'm not about to half ass it after having dropped so much coin on these brakes. I want every last ounce of performance increase and I want it from the date of installation.
Actually, in the pic you posted, your pads look good ALBPM. They don't look like they have that beveled edge on the pad material.
Here is the part I got from AutoZone : if there was a bevel on mine it was not noticeable.
Duralast Gold Cmax/Brake Pads - Front
For your 2006 Toyota Truck Tundra 4WD 4.7L EFI DOHC 8cyl
Part Number: DGC976
Features & Benefits
Maximum ceramic brake pads have a friction material that is formulated for ultra quiet stopping performance with low dust and a longer life as well as shorter stopping distances which makes Duralast Gold Cmax the brake pad of choice
•Hardware kits included where applicable for one stop shopping with everything included in the box for a complete brake job
•Rigid steel inner shim is a fundamental part of every brake pad and when combined with the nitrile rubber shim layer the vibration and noise is virtually eliminated
•Powder coated steel backing plate prevents corrosion and includes an acrylic adhesive layer to aid in vibration and noise suppression
•Slotted and chamfered friction blocks match the original equipment design
Part Number: DGC976
Weight: 4.85 lbs
Warranty: Limited Lifetime
Notes: Premium ceramicUltra Quiet with patented nitrile rubber shim. Disc hardware included.
Brake Component Height: 3.05 in.
Brake Component Length: 5.3 in.
Brake Component Width: 0.22 in.
Brake Pad Anti-Squeal Shims Included: Yes
Brake Pad Type: Ceramic
Brake Pad/Shoe Material: Ceramic
Built-In Wear Sensors: Yes
Color / Finish: Black
Component Hardware Included: Yes
Package Contents: 1 Set Of Disc Brake Pads
Performance Item: OEM Standard Part
Wear Sensor Type: Mechanical
