Panhead Jim
Hi, all. I'm new here. I came looking cause I think I've got a serious problem, and I have had great success with other forums such as chevytalk, jockey journal, etc.
I recently purchased my first ever Toyota, a 1994 4R with the 3VC-E motor. The harmonic balancer just fell off after some time of wallowing around on the crank. I've bought Chilton and Haynes, and neither provides the help I need, so here I am.
The balancer has a keyway all the way through, and the crank has a key that stops at the belt guide. Neither the key nor shaft keyway protrudes at all from the belt guide, so the balancer cannot be keyed on that key. Please shed some light on this whole situation. Both manuals say to "line up the crank pulley (balancer) with the key and bolt it down." I can't tell for sure if the crank is tapered or not, but I know it requires the bolt type puller under normal circumstances to pull the crank pulley. So help if you can. Thank you very much.
