Seymore Butts
I'm considering replacing my conventional starting battery with a Bosch AGM battery. I see on the label that it's optimal charging voltage is 14.4 +/- 0.2v
According to my system voltage monitor, the alternator puts out 14.1 volts for a few minutes after starting the engine, then the system voltage drops down to a range of 13.2 to 13.8 volts for the remainder of the drive.
I'm wondering if the AGM battery will always be somewhat below full charge or will it just take longer to reach full charge than the standard flooded battery.
