Has anyone removed the running boards from a 2012 SR5?
stdjones
Looks like the plastic "chrome" needs to come off as well.
How does this look?
Is it awkward around the wheel wells?
Pictures appreciated.
thanks!
How does this look?
thanks!
Welcome to the forum!
Running boards or rocker panels? You can see plenty of SR5's in the owners picture thread without running boards as they didn't even come stock on 2010's or 11's . http://www.toyota-4runner.org/5th-gen-t4rs/57313-5th-gen-toyota-4runner-owners-picture-thread.html
If your talking about removing rocker panels ,looks like this......
Picture022.jpg~original
Pa-4.jpg~original
Interesting - I guess I mean both the running boards and the rocker panels.
Can you remove the running boards without removing the rocker panels?
Looks like removing the rocker panels exposes quite a bit of the undercarriage.
How do you like it?
Could you put rock rails on to make it look better?
Or could you get trim parts from a TE?
Thanks!
Building on Harpers reply, if all you are looking for is to remove the Running boards themselves, get on you back and slide under your vehicle. You will see 6 "nuts" 2 per brace. You can't miss them. Remove the nuts, brace will fall in your face. Running boards will fall on your chest. No need for photos, they will only be U-tube fodder......be safe.
Stdjones has opened a can of worms asking about Harper's ride and covered all the bases without even knowing it. No running boards, rockers, TE parts, rails? Read a little here http://www.toyota-4runner.org/gallery/58037-june-2010-t4rotm-harper7.html and you'll see what I'm talking about. You'll also learn about lifts, 305s, different wheels every month, dual batteries, 3m coverings, roof racks, gears, etc, etc.
Edited to add: life, daughters, girlfriends, custom fabrication, hidden winches, bad-assery, etc, etc.
Edited again to add: jet airplanes, auto/body, sound systems, custom retrofit headlights, etc, etc.
Rialm
