having a new problem
forerunnin
Well after fixing my oil cooler leak and manifold leak, I have yet a new issue. My truck has developed a vibration from 0 to 60 . Where are some of the places I can look? I find that when I'm on the gas it vibrate more than when I release the gas. The whole truck vibrate . What could it be ? I checked the tires and rim weights. Could it be the driveshaft ? The rear diff ? Thanks
Mike
Check your motor mounts, they may be too worn to absorb vibration. Or bolts may be missing :(
U-joints or Front half shafts (there always spinning even when out of 4WD, unless you have fully unlocking hubs).. Thats where I'd go first... Another tip, pump grease into every u-joint fitting front to back, and front end components... If that temporally fixes it or makes it slightly better it will help you pin point it.
