Having trouble pulling CEL codes from ECU
M-Piers97
I bought ELM 327 OBDII Blutooth scanner to use with the Torque app to run my CEL codes and get to the bottom of my misfiring problem, is there a trick to pulling codes from these things? My phone says it cant connect to the ECU?? I know the scanner works because a ran the the codes in my dads 02 Tacoma and it worked perfect. Any help would be greatly appreciated
Not 100% sure if it's the same with toyota, but on a lot of cars, if the cig lighter fuse is blown, you can't access info from the OBD-II port.
Try with the engine running if you havent yet. I have one of those cheap BT readers too and it or my Torque app likes the engine to be running. On a side note, I just pulled a P0300, P0301, and P0302 - misfire codes. Fixed with new plugs and wires.
Yep, i tried it with the engine running and not running
Actually, our trucks have a separate 7.5A OBD fuse in the engine junction box. Full circuitry on page 62 in the attached. I'm pretty sure cig lighter power is not involved.
There were two fuses in the fuse box inside the truck that said OBD on them and both were not blown, is there another fuse somewhere?
I'm a total noob on ECU's.... Can someone explain where I can see the codes if there is one. Would it just be on the dash or do you need a tool to read them?
You need a code reader of some sort, if you have a Android phone you can get a app called Torque and buy a Bluetooth code reader or you could just bring it to a auto parts store and have them run the codes with one of there computers
If you have an iPhone it won't work with Bluetooth. They make a wifi version that does.
Good luck
Utep
Look into ScanGage II tool. It mounts in-car and gives you real time info. I run one, and it's been a life saver.
Durk, where is that fuse located? and the PDF is not working, could you email it to me?
Ok, i found OBD 7.5 fuse and its not blown. I dont know what to do next, are there any other things that could cause a OBD to not let me run codes?
Try this link:
http://tacoma.site40.net/4Runner_96-02_Repair&Wiring/techinfo.toyota.com/ileaf/ewdtmc2/ewdtmpdf/ewdsourc/2002/024runne/systemci/015ecs.pdf
Can someone else confirm that attached .pdf in my post above is dead, please? It works for me. I am trying to upload these instead of using links because the links may die. Hundreds of posts of mine went south when ncttora pulled their FSM's off their site.
Try this link:
Thanks, it might just be my Winrar thats not letting me view the PDF
THANK YOU!!!!! I tried OBD car doctor and it worked great!!!! I have a misfire on cyl 6 and a bank1 sensor 2 o2 sensor bad
Really glad to hear that worked for you. :reddance:
Its a great app and I prefer the layout of info to all the other apps I have tried. Its straight forward and easy to use.
I also like that you can disconnect from the devices bluetooth and then close the app. This way I know I wont disconnect the OBD reader while it is in the middle of some process and potential get it frozen there.
Now how are we going to fix that misfire? Hope its something simple like old plugs.
Yah im really glad it worked too :party:
As for the misfire....well lets just say its been a up hill battle for a while now, i replaced plugs and wires and all 3 coil packs so at this point i am going to say its a bad/clogged injector
premiumusedautoparts
