HaydenATX's '15 TE-The Yeti
toothpick or a jewelers screwdriver:cool:
thread jacked:clock:
Is there a minimum time after the last coat that you should start to peel? I read somewhere people said let it sit for 10 mins and then remove it.
:deadhorse: im putting this in there cause its cool.
This guy looks familiar :rapture: haha
This is my first experience with the pdip after people swear by it.
So you sprayed over everything and then just started to pick and peel? I heard WD40 helps... you just finger nail it?
Yep just tape around it and leave about an inch on all sides. If you do 6 coats or so it peels right off of the plastic. I used a small point on a plastic trim tool but I think tooth picks are ideal.
I let it dry for 15 minutes before peeling off. Just take your time when removing the excess
Installed Lamin X fog light covers today.
How hard it was to do the 3M wrap on the rails...did you do it yourself or had someone do it for you. I had a quote for $150 for the roof rails and $300 for the front and real valance. :help:
Suuuper easy. I didn't even use water. I did it in like 10 minutes and ended up with a few creases but they're not noticeable. $30 for the vinyl. I would definitely recommend diy especially with those prices
How hard it was to install the front and rear valance? Did you install it yourself?
I am thinking of doing like you did and buy the TRD black valance rather than vinyl. :hug:
I need to Lamin-X my fogs. Looks great!
You running stock bulbs in them and your headlights?
Took about an hour total. There are several threads on it.
Got it from [MENTION=22701]hookem[/MENTION]Horns I believe he bought it online. It's 3M flat black. About $30 a roll.
Any problems reinstalling the cross bars after putting the vinyl on? Tolerance issues...? I can't imagine the stuff is thick enough, just want to make sure before I order the vinyl. I'm kinda over plastidip for a while.
No I just cut the vinyl before it hit the track on the inside.
matisgugle
