airborneranger
Anyone else have headlight beams aimed too high from the dealer? When I have some stuff in the truck like 4 people its really noticeable.
It's actually on the back of the lights.It's a 8mm adjuster bolt but I don't remember which way to turn to lower the lights.Somebody pitch in which way if you do it or know.Anyone else have headlight beams aimed too high from the dealer? When I have some stuff in the truck like 4 people its really noticeable.
I have received a few 'flashes' from other drivers, so I have a feeling they are a little high. I think they are surprised when I flash back with my real 'highs' though :lol:
I had to lower mine when I did the front lift as they were way high then.The lights were shining off the back of peoples heads in front of me the first night out. That's not good!You should keep the light cutoff at or below a small subcompact car's trunk height in front you. I shot a pic of the passenger side. It's the big silver bolt in the middle and takes a 8mm wrench or socket.
<a href="http://s420.photobucket.com/albums/pp282/gharper60/?action=view¤t=Picture086.jpg" target="_blank"><img src="http://i420.photobucket.com/albums/pp282/gharper60/Picture086.jpg" border="0" alt="Photobucket"></a>
The best way is to adjust it in front of a wall or garage door at night.
Can anyone confirm which direction to turn the adjustment screw in order to lower the headlights? In various threads on here I have read clockwise AND counterclockwise.
+1. Best way to do it is to try it out. It's more than obvious which way the light aims as soon as you turn the screw.I suggest you turn it one way, and if that doesn't work, turn it the other...:biggrin2:
