T tla11384 New member Feb 8, 2009 #1 Does anyone have any ideas of getting rid of headlight moisture? NEED HELP
ChildrenOfBodom Moderator Feb 8, 2009 #2 tla11384 said: Does anyone have any ideas of getting rid of headlight moisture? NEED HELP Click to expand... My right headlight had a lot of water in it once. In order to clean it, follow these steps. Remove the headlight from the car (requires removing the grille) Once the headlight is out, pour out anything Take it inside and hold a blowdryer blowing inside the housing, make sure the hole is pointing up so any evaporation can escape Don't use anything too powerful, the reflective film will come off. after the blowdryer looks like it's removed the moisture, leave the headlight faced down with the hole up overnight re-install the next morning and make sure the rubber boots are sealed correctly.
T tla11384 New member Feb 8, 2009 #3 Thanks for the advice!!! Did the moisture return after you fixed it?
