Headlight Moisture buildup???
tla11384 said:
Does anyone have any ideas of getting rid of headlight moisture? NEED HELP
My right headlight had a lot of water in it once.
In order to clean it, follow these steps.
Remove the headlight from the car (requires removing the grille)
Once the headlight is out, pour out anything
Take it inside and hold a blowdryer blowing inside the housing, make sure the hole is pointing up so any evaporation can escape
Don't use anything too powerful, the reflective film will come off.
after the blowdryer looks like it's removed the moisture, leave the headlight faced down with the hole up overnight
re-install the next morning and make sure the rubber boots are sealed correctly.
tuṣṭāva
