NDRYDEN123
is there any other way than wet sanding my headlight to remove the yellow haze/oxidation on my headlight housing. it seems that most of the haze is on the inside of my headlight houseing. thanks in advance for any insider info.
oneflat83 said:same things as a color sand...yup that works too. most people on here probably wont go through the trouble. Ive heard of clear coating the tail lenses to make them look new again. i wonder if you could do that on headlights...or would the heat not be good? i wonder
MikesToy said:i'm lazy. In case my headlights oxidize, i'll just buy new ones.
pmrowczynski said:What about putting on the 3M type of plastic protection on it? Not only does it protect against chips as a physical layer, but the adhesive & plastic should prevent oxygen and an oxidizing reaction, no?
NDRYDEN123 said:Haha that works too. I just didn't want to spend over $250.00 for the housing.
KarenCaren said:lol... Probably I'll do this too. If you are doing it the 1st time and fail to achieve a good output you will have to buy a new one. Suggestion: GO to a detailer and watch how he do it!
______________
Thepartsbin
broncosi said:Then there is another solution you can find at autozone or pepboys or whatever auto parts store is around. I think it is also made by 3M but it is a gel/paste kind of like a liquid wax that you buff on by hand then just buff off. This worked for me on an old set of headlights just fine.
I used this kit on my wife's Corolla and it worked perfectly! The lights look brand new!3M makes an at home sanding kit that you just use with a drill. I have seen that work 99.9% of the time.
