Hello All,
I have a '97 4Runner Limited with 181K miles. Sometimes when I'm running with the low beams on the lights turn off and the high beam indicator light in the dash turns on. When I pull just slightly on the turn signal/high beam lever the low beams come back on and the h/b indicator goes out. Do you think I just need to replace the turn signal/high beam switch assembly or is there some relay that I should check first?
