Headlight Questions
Each headlight requires only one bulb, that is due in part to the dual filaments in each H4 bulb. So you have two headlights all you need are 2 H4 bulbs and that will replace both high and low beams.
One last question... Sorry.
I've read a few people say that using a higher watt bulb will fry things up pretty quickly. I don't want to change the harness/wiring now or down the road. Does that mean I should go with the 55/60 Watt bulbs?
Philthyphilthy
