Headlight Warning?
singleshot
Did the 2007 Sport come with a warning chime/buzzer if you forget to turn your headlights off when you turn off the engine and exit the vehicle?
My 2008 doesn't.
Also, from the manual:
Automatic light cut off system
Position 1—
The lights automatically turn off when the
driver’s door is opened with the engine
switch in the “ACC” or “LOCK” position.
Position 2—
The lights automatically turn off after 30
seconds when all the side doors and back
door are closed with the engine switch in
If the “LOCK” switch of the wireless re-
mote control transmitter is pushed twice
simultaneously, the lights automatically
turn off immediately.
The time before the headlights turn off
can be changed. For details, contact your
Toyota dealer.
If the driver’s door is kept open, the lights
automatically turn off after 30 minutes.
To turn them on again, turn the engine
switch to the “ON” position or actuate the
headlight switch.
If you are going to park for over one
week, make sure the headlight switch is
off.
Either tap twice with the lock button with all the doors closed, or just make sure the doors are closed and key is off and the lights turn off by themselves. If you want I think you can change the feature somewhat through the TIS Techstream, but there isn't a chime.
Jhunt
