Headlights off Without Opening Door
Is there a way to make headlights to auto-turn-off w/o opening doors post shutdown?
  • Yes, I will share the info now
    Votes: 4 66.7%
  • No, I have verified it is impossible
    Votes: 0 0.0%
  • TLDR; I don't care about you
    Votes: 2 33.3%
  • Total voters
    6
Seems easy enough. Hope I can find time to give this a shot this weekend! Thanks!
Gray connector on brain, solid orange to the red wire at fusebox shown in the pic.
To test when done, remote start it, then deactivate the remote start with the remote and do not open the door. The lights should time out under a minute.
The Compustar can be wired to trigger the door pin on shut down. Depending on which Compustar, it's most likely Orange wire rearm output to the drivers door pin which is red. It will pulse this wire briefly wit ha ground trigger tricking the vehicle into thinking the door opened then closed.
This will most likely trip the factory alarm, assuming the doors are locked (which they should be).
alexaturner
