Headliner removal?
skategoat
Has anyone completely removed the headliner in a current gen 4Runner? Looks like I'm going to have to do that to install a roof rack. Is there any adhesive involved or is it just hardware?
Thanks,
Henry
No I haven't removed it, but I think the dealer took it down partially to fix a rattle in mine. It should be easy since they just put it right back. What rack are you putting on? I take it you're removing the factory rack? Or did you not have one? Let me know what make and model you're going with and how the process goes, I was thinking about doing that myself. The factory rack is only rated to 150 lbs. I have a yakima megawarrior on it and then once you put a kayak, mountain bike and gear up there you are way over 150 lbs.
Herman
I have no rack. I think I'm the only 4runner on the continent without a rack. I'm looking at the factory rack and the Sportrack. I know of no others that fit the factory holes in a 4runner. Do you know different? I think the Sportrack is rated for 200#,
I don't know of any other racks that fit the holes, other then those. And I didn't even know there was a different Sportrack, I thought all were the same. Do you need to removed the headliner to put in the factory racks? Good luck and let me know what you end up getting.
Herman
