SkidPalace
Member
I wonder if anyone has experience with a sticky temperature controller (analog rotary) on a 2000 T4R SR5?
I noticed during a rare cold spell early in the summer that it had a hard time moving towards the hot range.
I just applied a bit of pressure and it eventually freed up.
I just went to crank on the heat last night and it was sticky again.
I applied a bit of pressure and it didn't budge. I applied a bit more pressure and heard a snap in the knob istelf.
So anyway, I looked under the dash and followed the cable to where it attaches to what another post referred to as the blend door (the white plastic linkages at the bottom of the heater unit). I uncoupled the cable from the mechanism. The knob and cable move perfectly without resistance. The linkage, however, is very difficult to move but it does move by hand.
Although the heat operates to some extent without the operation of this blend door, I would like it to operate properly.
Is this something that can be lubricated, or am I out of luck.
Since I forced the temp knob too much, I will have to get the blend door linkage to operate very smoothly or else the knob will likely continue to jump its gears.
Any suggestions?
Any suggestions?
