Heater core removal
Heater CORE Replace
? Does not sound like the heater CORE was bad, if the dampers were frozen open! DId you replace the heater BOX or the core? From photos, I do not see a way to remove the large heater box without removing that cross bar, what exactly did you replace?
Thats right, heater core was fine, the heater box the core goes in was not.
I removed the large black heater box without removing the support or crash bar. I had it loss so I could push the bar up out of the way a few inches and removed the box from under neither it.
Thanks a bunch for the pics and awesome write-up!!! A week ago my heater core went out or so i think. Heat is only warm and there is distinct coolant smell followed by a dash fogged out with what i believe is coolant mist when defogger is turned on?
Over the Christamas break it finally snowed(and froze) here and my leaky heater core went from an inconvenience to an emergency when ice gathered on my window to where i could not see at all. I thought the windshield wipers would keep it from accumulating but that worked all of 5 min. Toyota quoted me $1145 in labor and an independent shop said $450. Now i will say that this is the largest job i have ever tackled on a car or truck and it would have been well worth the $450 paying someone else to do it. However i had already spent over $300 on new Toyota heater core along with the pipes and with this thread i decided to tackle it myself. Wow what a job! It took me about 8 hours of actual work. I spread it over 2 days mainly because i had to order the pipes that lead into the heater core...mine had corroded to where there were tiny pin holes in the tubing! The only thing i might add to this thread is pulling apart everything is easier than remembering exactly how is all goes back together LOL. Pay close attention to where the climate control cables go in relation to the support bar, IIRC the one that goes UNDERNEATH is the black valve control cable, dont quote me on this just make sure you either remember, mark it, or take a pic with your phone. Thanks again to the original poster for this thread and all the pics, this should definitely be a sticky!:thanks:
OEM vs. Aftermarket
I am about to tackle this one my self. I have by passed the heater core in the engine bay so i am not in a huge hurry to get this done but i am rounding up the parts that i will need in order to complete this. My main question is if it is necessary to use a OEM Heater Core or if i can go after market? The difference is about $200 from what i can tell pricing online. I was thinking this is not a super critical part like LBJ's but on the same token it is going to take a lot of work to get to it. Just looking for feedback from someone with experience or the knowledge on why the oem is so much more.
Heater Core
I sold the car before I did this job but I did buy the heater core. I did not buy OEM instead bought one of the better known aftermarket brands - looked ok /well made to me! OEM is always more expensive - for engine components I would go OEM but not a heater core. Get ready to pull your dashboard out have fun and use the right coolant always.
Thanks for the response that is what i was thinking. I will probably go aftermarket. Not looking forward to this one but the quotes i got are outrageous for labor.
I live in Los Angeles. There are always street mechanics here that will do most big auto jobs for peanuts, including this one. Somebody quoted me $200 labor for this and there's plenty more guys that will be happy to do it for that. Anybody but me. After seeing photos of this job I'd rather walk through the Mojave Desert. Here's another big helpful tip for you older 4Runner owners: Stay away from ball joint replacement - especially the uppers. That is one huge mothering tough-assed job and it usually requires the spindle to be completely removed and taken to a press shop, yes sir no fun there, so DON'T GO THERE. Control arm bushing replacement is another nasty job - I SAY if the front end is shimmying and banging, it's time to move on. Because EVERY BUSHING needs replacement and the BJ's too. Whew.
Flushing the heater core
Hi, thanks for the detailed instructions. I am not getting much heat out of my 96. There was significant rust in the cooling system, which has been flushed.
Has anybody tried soaking the core in radiator cleaner and flushing it with water?
I want to try it before committing to a full removal.
Thanks!
Do this please
I got plenty to say about all this, although I don't have my Toyota 4runner anymore. I would try to flush the rad manually by disconnecting hoses and using the garden hose approach in BOTH directions to GENTLY flush it clean, then possibly run it with rad cleaner as per directions and reflush. And then DO what I DID NOT DO - which is to fill it with genuine Toyota radiator RED coolant for aluminum cyl. head engines. Use the absolute top quality correct coolant for this engine especially if you have a V6. I used the green crap which states "suitable for use in all engines" well guess what - THAT %%^&*#$$ CRAP is what failed during a hot run up to FRESNO, causing rust which BLEW my engine not once but twice and it happened REAL QUICK. Do NOT USE ANY substandard coolant, spend your money for the BEST. Arrggghhh!
Great pics.
(I'm about to well at some point) flush out the A/C evaporator, replace expansion valve and all seals, so I might as well do the heater matrix while I'm there.
Along with removing the doors windows and tailgate, the dash is the only remaining part of my truck that I have not taken apart. :bounce:
Massive cleaning opportunity awaits!
Heater core suggestions
I have a lot of good info on this post and I am about to try and do this big job this Coming weekend. I have a new heater core. And a new A/C Kit that includes the compressor, dryer, and expansion valve and a bag of seals. My goal is to Replace the expansion valve, and the heater core while I am in there.
The A/C has been depleted by a shop. And this weekend is go time! But I have a few questions and I cant find a way to start a new post so I'm sorry for using this one.
Any concerns about the airbag going off during removal? Is it safe as long as the battery is disconnected?
Any other parts I should check or replace while I'm in there? I have a 97 4runner 2wd 6 Cyl about 400, 000 miles. Any extra info would be much appreciated!!
Here is my point about the heater core. Try NOT to mess with it if you have good heat. Just flush it many times if you want to.
Getting the ac components out and back on is easy. But, why you want to replace all that? Here is how you check the compressor. Hold the high side by placing your thumb as to make a good seal. Then turn the clutch (not the pulley) by 15 to 20 degrees. Do you feel lots of pressure build up under the thumb and hard to hold? If so your compressor is good. My DD is a toyota sprinter "aka geo prizm" (92) with 265K miles. I use the AC a LOT (west TX is hot) but the AC is ice cold and still the factory gas and parts all around. Make sure you clean the condenser often.
Is there a drain for the heater core if its leaking? I think mine is leaking but theres no spillage or smell in the cabin. Just every time i start the truck after its been sitting i hear what sounds like the heater core filling up with coolant as if it drained empty.
If heatercore is leaking it will drain through the AC drain. How is the coolant level in tha radiator and the reservoir? Do you have to fill it often?
The resivor goes about half down every couple weeks. I can smell it out side the car, but only sometimes see apots on the ground
I’m about 2/3 of the way through replacing my heater core on a 1999 SR5. It appears to be the original unit, which is impressive considering it was 20 years old and had been on there for 396k miles. The original post with all the pictures was phenomenally helpful. I wanted to add a few comments for anyone that may reference this thread in the future:
-take the center console out first. You’ll need the room to move around.
-all you need is a T40, 10mm, 12mm, 14mm, and Phillips screwdriver
-probably goes without saying, but don’t forget to remove the hoses from the heater core in the engine compartment. Also, pull out the rubber grommet to reuse later
-having both front seats out gave me a lot more room to move around
-I was unable to completely remove the metal cross member tube like the OP did. There are far too many wiring harnesses strapped to it and I didn’t feel comfortable moving them all. However I did unbolt it on both ends and pulled it back from the passenger side.
-getting the heater box pulled back and rotated far enough to access the heater core is really challenging with the crossmember in there but it’s possible. Getting the factory one out was easier because the short sections of pipe from the core to the engine bay can be disconnected. However, the replacement unit I bought had the short pipes clamped on and it was therefore a tight fit to slide it into the heater box but I eventually got it. The OP showed removing the airbag module (the three T40 torx screws) and I also removed the ABS module to give me a little more room.
-I have the manual A/C controls and i did not remove the climate control unit. I did however unhook the cables for hot/cold and vent/recirculate from where they terminated.
-I laid out a piece of plywood on saw horses and labeled every bolt I took off and noted where it came from. This made reassembly much easier and I didn’t worry about missing anything.
-separating the two halves of the heater box was pretty challenging. Getting them lined up again and back together was even trickier
-there are two metal supports that attach at the trans tunnel. The OP removed the bolts at the tunnel but not at the top. I also removed the top bolts to provide some more room since I didn’t remove the cross member.
-as someone else mentioned, it was a great opportunity to clean all the trim pieces as I went along. The PO was a smoker so there were ashes and grime on everything and I was really able to get things clean.
I still need to get everything buttoned up tomorrow so if I think of anything else, I’ll update this post.
Reviving an old thread....I have coolant puddling in my passenger footwell. I checked the hoses going into the heater core in the engine bay and they are dry. Is this a bad heater core or are there any connections/hoses in the cab that can be replaced?
Kristian
Kristian
That’s exactly what was going on with mine. I had a lot of leaking in the footwell and engine bay was dry. My heater core was corroded and leaking into the heater box and into the footwell
