Hello T4R.org
UWISHU1
My name is Angel I live in IL and I've been lurking for a few days trying to find out some info on these trucks.
I've had my eye on a 2001 T4R limited and was hoping you guys could give me pointers in what to look for.
Is the asking price($8900) decent for the (122k) mileage?
2001 Toyota 4Runner Sport Utility SR5
the car fax shows 2 previous owners, I plan on going to check it out tomorrow morning.
Thanks in advance for your help.
Looks clean :thumb3:
Always did dig the white T4R's. And a moonroof, sweet...
I'm sure others could chime in with more advice than I can offer, but i'd say just be sure to check over the maintenance records as closely as possible, especially for the major milestones, 30k, 60k, 90k... timing belt, plugs, fluids, etc...
Here's a link that you may want to check thru, or even print and take with you tomorrow:
Toyota Parts and Service
Just work your way thru the intervals and look at the major ones, should offer you some heads up on what to ask.
Hi Angel,
That looks like a great deal from what I saw shopping around here (DC area) over the last few weeks while searching for mine. Initially searched only for 3rd gen, but in the end spent a little more to get a 4th gen with v8.
That's definitely a good price imo, and had I saw that here I think it would be in my driveway now!!
Well just got back from the dealer what a disappointment. On top the rear ended rear bumper and the cracked rear tail light I was willing to over look. I get in the drivers seat and most of the lights on the dash are lit. ABS, Brake!, TCS OFF, TCS ***, door ajar light. Tried to engage the 4WD and the 4WD display was flashing all 4 wheels then the green dot in the middle would switch from solid to intermittent flash. Quite honestly I don't think the 4X4 wasn't working or engaging, IDK. :rant:
Yikes, that sounds like one to be weary of. Sucks to have the disappointment after finding one you'd like to have.
Wow, don't they have a mechanic that works there? What did the salesperson say about the dashboard xmas tree?
Bummer!
So that's why it was priced low. Did all those lights remain lit after it was running? If so that sounds like a bad sign for sure.
Did you actually drive/move it? Not sure if 4 wheel drive fully engages unless you move it at least a few inches.
Bottom line though, I wouldn't want one that's been rear ended anyways. Best to keep looking.
that's what I thought. He said they were going to look into it to see if it was worth fixing to sell it. I'm thinking WTH would you even try to sell it in such condition.
yes all the lights remained lit through the course of my test drive. I tried to drive over some deep snow and proceeded to get stuck so I had to back out.
Geeez, apparently that sucker is chock full of issues. don't just walk away, but run from that one!!!
My used sales experience wasn't trouble free.
Here's what I went through last weekend with a Toyota stealership, drove 75 miles to see the one I have. Drove terrible, pulled to the left and had the womp womp womp sound coming from the cupped tires. So I said if they swapped the Bridgestone's on it for the Michelin's on the 4R next to it and let me drive it again to make sure if wasn't a front end issue I would still consider it.. so about an hour and a half later I take it for a spin with the Michelin's and it drives a lot better but still pulls a little.
I ask for an alignment check and if its out I will drive it again after its aligned, if it doesnt need adjustment I am leary it has balljoint or other issues. So it turns out the toe was out and I go for a final spin and I'm happy at last.
got there at 930am, signed the deal and drove away finally at 530pm.. what a long @ss day!!
Also after the deal was complete I asked where the floor mats were and they said oh if they aren't in there then they were threw away apparently, as we don't sell them with wore out mats, our recondition guys are told to pitch them..
Luckily I had been in another one on the lot with perfect factory all weather mats and I insisted those go in my 4R, So that was good. because I prefer them anyways!
Only had one key and fob.. another thing I found out at the last minute.. and those cheap skates wouldn't cut me another one, well for about $120 they would, but they are sending me a free fob that I will need to program and I went yesterday to a local locksmith and had a chipped master key cut for $85, and a slug key for just the doors for $2..
All in all I got a great deal on it, but wish I hard bargained on that key before I struck any deal with them.
Because if you lose the only master key to my model your looking at a tow to the dealer and a replacement of the immobilizer computer as well as the price of new keys..
They are more than accommodating and just about willing to be your new best friend until you sign for delivery of it, after that, its good luck sucker ;)
Also after the tire shine wore off it turned out the tire's were extremely dry rotted, manufactured in 2005, and had only 3/32" of tread left, so I put a brand new set of Michelin LTX MS2's, to the tune of $1k, but that doesn't bother me as I like putting the tire of my preference on, and the ride and handling of a new set.
The new tires, keys, and front window tint I did yesterday bring me in a couple hundred under 16k total at this point.
So things to keep in mind maybe for you!
Well after a lot of searching I picked up a 2006 Rav 4 V6 60k miles from the original owner.
Captivating via tapatalk
