Hello..what size speakers are my JBL synthesis system?
orangeblast22
Just got my 2006 Sports Edition 4WD V6 and it came with the JBL synthesis system..sounds good...but I'm still probably going to go aftermarket and wanted to know what size speakers i'm dealing with here.
I know this much:
Sub = 6.5
Fronts = 6x9
Back doors = 6.5
Center = 2.5
Back Pillars = 2.5
Front Tweeters = 2.5
is this right??? I planned on disconnecting the back pillars and back door speakers...don't need the rear fill...but wanted to put in some front components and also utilize the center channel speaker...just don't know how I'd wire up the center chanell and how I can get it to work properly. Would hate to have an aftermarket system in and just have an unused center speaker sitting on my dash...
any thoughts?
I think the sub is a little 8 inch.. You can usually Y off one of the channels for the 2 channel you'll run onto a single amp.. and turn it real low to power your center channel. That's how my coworker's competition truck runs.
hrm.....
how do you gain access to the center channel on the dash...looking to put in a bigger speaker or something..or maybe just disconnecting entirely and using my Hi end components to do the staging and imaging....shouldn't be a realy problem considering that they are Seas Lotus Reference spekaers. mmmmmmmmmmmmmmmmmmmmmmmmm............
If I could use the center channel for something then I'd be in business...perhaps do some cutting to make room for a bigger speaker...dunno though...
