Help - 2006 4Runner OEM Gas Tank Depth and Fuel Sender Heigh
Charles4x4
I’m getting dimensions for a fuel cell and am going to try to use the stock sender unit with URD Pump/Filter upgrade. Two questions:
1) How deep is the stock gas tank where the fuel sender goes in (distance from fuel sender to cap to the bottom of the tank?
2) How tall is the stock fuel sender? (Vertical height)
I’m looking at a 22 Gal fuel cell that is just over 10” tall and a 32 Gal that is over 14” y’all and want to see which one matches the stock fuel tank closest.
My best estimate with the tank installed is 10.75” for #1 above. It’s a bit hard to measure though.
Which means #2 is less than 10” is my guess?
If so, the 22 GAL with a depth of 10.5” should be close to perfect for the OEM sender.
utkrstam
