Help! 99 4Runner wont start
bojorkez
Hello I have a 99 4Runner V6 that would not start this morning. I just replaced the battery 2 weeks ago. When I go to start it, it does nothing no clicks, does not try to turn over, nothing. Lights, radio, door chime all still work. No clue what it could be. Any suggestions? Thanks for your help.
Have you tried to jump it? It takes a lot of power to start the engine vs. run the little lights. If you try to jump it and still nothing, I'm guessing starter at that point.
Time to get the test light out and see if you are getting power to everything. That is first off, then just follow the leads around until you find where the power loss is. Was the Batt bad in the first place? It happens some times from them sitting on the shelf for to long.
Blue
Check your 100amp alternator fuse under the hood. Could be that. If it is, it is screwed in from the sides and you have to take apart your fuse box.
