Help-Brake Line Diameter
Snowshoer
Blew a rear brake line on my 2004 Sport 4.7L the other day. It is leaking and looks to be above the rear axle or main line running from the front to back. Either way, I for the life of me can't find the diameter and fitting size so I can replace it. Can anybody help with that? Also, does Toyota use the standard flare or something different if I have to flare it myself? Thank you.
Thanks, I was thinking it was the 3/16" line with a M10x1.0 fitting. I want to get the line first before tearing the rotted section out. I am hoping its not the long run from front to back over the tank. I have to check it tonight.
seltzernator
