Help!!! Car is stuck in "park" ----> Won't shift to drive!!!
jc27 said:
The dealership charged me $85 to get the whole thing done. For those of you who are hardcore DIY-ers, the part cost about $35.
Same thing recently happened with my 2003 Limited 4Runner. Brought it into Castle Toyota and Grant and the crew were able to fix it for me. In and out of the door for $80. Only problem was they didn't have the part, so I had to wait a day.
This was an on/off problem for about 3 to 4 months. Until about a week or two ago when the VSC TRAC, VSC OFF, and ABS lights were on all of the time. I got tired of my dashboard looking like an X-mas tree and brought it in. Before I got it fixed, sometimes I'd be able to shift out of park if I stomped on the brake pedal. For about a week until I brought it in, I was using the shift override method.
But yes, I thought it was going to be a pretty expensive repair.
It has to be a brake light switch, VW's had a lot of issues with those, had the same symptoms too. Their switches were only about 35 bucks, I'm not sure how much Toyotas are
Thanks for this very quick info. I finally made it through. I just found somethings worth trying at last. I am struggling for 4 days now.
____________________________
Gas engine fuel saver Tips
:yo: Thanks T4R.org and the OP for helping me save some $ troubleshooting this issue. I got my switch from Camelback Toyota internet parts for $22
4runner messed up
Hello. So a 1996 4runner with 316 000 km, was running fine. Then signal fuse blew, replaced with a spare. Then temp gage, tach and speedometer stopped working. Stereo lost power next. Got it parked and shut off. 15 minutes later tried to start it again, didn't want to start, but eventually did.
Then couldn't get it to shift from park with break fully depressed.
The throttle was very delayed from any input and eventually she just dies.
Clicks when I try to start again. Low battery. Got a boost, fired up no problem. Stereo even came back shortly along with throttle control. Then it died, would sputter when given some gas.
Any suggestions? Much appreciated.
jc27, if you are interested I have 3 pdf files from the shop manual that I can Email you with a description and drawings of the location, removal and installation of the brake switch on a 2007/2008 4Runner.
CAD-Man
CAD-man! Can you send those documents my way as well? Looks like I'm having the same problem on my 4runner. my email is [email protected]
I had the same issue. I first noticed something wasn't right when I was driving to work and the ABS light came on while I was stopping. I thought it was because one of my brake calipers is seized (I know I plan on fixing it ASAP), but the light went off about a minute later. ABS light came on again just before I got to work and then went off before I got to the parking lot.
When I left in the afternoon I noticed the shifter wouldn't come out of park, but I let go, pressed the brake again and it shifted into Drive. Later that night, my wife got in it and couldn't get it out of Park. After trying for a few minutes she got it into Drive and claimed it was because she turned the steering wheel to the left before trying to shift. I have no idea why she thought that did it.
The next day I couldn't get it in Drive and got my son to look at the brake lights while I pressed the brake. No lights on. So between that and this thread I figured it had to be the brake switch.
I found a much easier way to do it than what is described in the PDFs above. Follow the instructions in this video: https://www.youtube.com/watch?v=3Sja-CXlfBo&list=WL&index=12&t=0s
The switch is behind the brake pedal and slightly above it. It's easy to see without removing any panels or the brake pedal. It has a blue connector, remove that, twist the brake switch counterclockwise (like you would when replacing a headlight) and it should come right out.
Put the new one in, but make sure you push it all the way in before twisting clockwise to lock it. If you don't push it in far enough your brake lights will be on with the brake released and turn off when the brake pedal is pressed. Reconnect the blue connector and you're good to go.
This may or may not have also set off my VSC Trac lights. I just finished some repairs that spanned a couple months and I thought the VSC lights meant I needed to do a Zero Point Calibration. I did that anyway after replacing the switch and now my VSC lights are off.
Hope this helps someone else.
cant get my 4runner out of park
have a 3rd gen 4runner .actually read the manual and found a button with a plastic cover on the shifter console . remove cover and press in white button . when the break light fuse burns it does not send a signal to the transmission and will lock you out . a new fuse will remedy the problem . 75 cents! wonder how many people got F+++ed on that one
BillM777
