Help. Cranks but wont start
AnotherDude
1997 Limited 3.4l
So my daily driver decided to turn on me. Went out one night to start it and it just cranked and cranked but wouldn't fire up. I had just driven it a couple hours before. Noticed the tach was not jumping when cranking so I removed the crankshaft position sensor and ohm'd it out. Sensor was out of limit. Order new part from Toyota, picked it up and installed it. Still same issue. Cranks with no tach movement and won't fire.
Key on I checked the harness plug to the sensor and it's only getting 1v. It's a 2 wire plug so I'm not exactly sure how much voltage I'm supposed to be seeing there. Now I'm sitting here trying to figure out what it could be. Hoping to get some direction here.
Thank you guys in advance
I would check fuel pump. I had a similar situation and it was the fuel pump. U could have a bad fuse to fuel pump as well, but I think it is fuel related. Good luck
MikeM
Appreciate the input. I'll double check the pump. I replaced it almost a year ago exactly. But that doesn't mean it couldn't have gone bad. Thank you
If you didn't use oem toyota or a denso. It's quite possibly bad. The aftermarket parts on a pile of things are very vert bad. :(
seltzernator
